Guest pingos
Guest pingos
Hello Fibaro Friends,
as Devolo is not able to deliver I decided to be also a FIBARO friend.
I operate 4 roller shutters, three with selve Motors (13 years old) and one with a new Nobily Motor.
With this new Motor the Roller Shutter doesn't work as the other three. The roller react after the third Click and Remote Operation is impossible - but you can hear a Click by the roller shutter. Can the "Watt"- configuration (threshold) be the reason? Is there any not too expensive possibility to configure this value without the Home Center?
Its unbelievable that this Switch shouldn't work with this Motor...
Thanks a lot!
By the way:
I already exchanged two of the Modules - Same issue with the new Motor...
Edited by pingos
