Hello. I having problems with the basic authentication in all my browsers and a seperate camera sending call to my HC2. Works if I'm logged in to my HC2 in the same browser at the same time I sending the command.
Use this to generate the http
Edited by Urfalo
hi!
1st - login and password case-sensitive. 2nd login and password should be from local UI not from Fibaro clouds
    Thank you for the reply. I use it local. And Im 200%shure I typing it right. I have eaven converted the username an password using basic authentication header generator. Tried with the hex%40 %2E in the username and password for @ and . but no luck.
    If im logged in to my FIbaro, it work. When I type wrong password, it pop up username and password, and if I use the correct string, it goes thru. If I log out of my fibaro, the popup comes every time.
    Sry if old post, but I'm having the exact same issue.
    http://username:password@IP/api/callAction?deviceID=190&name=pressButton&arg1=5
    will always popup login prompt, even if credentials are correct.
    Anyone got any idea about this?
    EDIT:
    http://username:password@IP/api/devices
    This works, anything else doesn't authenticate and pops up login prompt. There is a bug 100%
    EDIT2:
    It's strange, sometimes it works, sometimes it doesn't. I ended up just using curl and basic auth with base64.
    More work but meh... Maybe someone can explain and I'll feel stupid :P
    Edited by Weider
