Cucullatus 1
Hi there,
Using the Heatit Controller running v1.8 firmware I notice three errors with Fibaro HC2 v4.80 firmware release:
1. The device template is incorrect for the Heatit Controller on v1.8 firmware. For Parameter 2 there should be 7 options not 6 that are currently listed.
The option 7 should be for "A2F" mode. This can be confirmed in the manual for the device on the Heatit website. Can the template be updated? Attached are screenshots for reference.
2. I understand that the Heatit Controller can run in securemode as it has the Z-wave 500 plus chip. However when pairing the device with the option "Add in security mode if device supports it" appears not to work as the resulting listed device does not have the "pad lock" like a device such as the Fibaro Dimmer 2 does. Can this be addressed? Attached screenshot for reference.
/monthly_2018_04/5ae1aa4cc5031_HeatitControllermissingsecuritypaddlock.png.111d51242f596c9ac18ee07292b94ea8.png" width="549" />3. After pairing the Heatit controller to the Fibaro HC2 you have two thermostats listed. The only difference between the two is that one contains the "off" function.
Can these not be combined? What is the reason the Fibaro HC2 v4.80 generates two devices?
Thanks!
Thanks!
Edited by Cucullatus9 answers to this question
