General sensor activity plots
Fibaro includes an energy panel for the graphic representation of actors and a temperature panel for similar purpose.
Is there a way to monitor and download the sensor data of other sensors, like humidity, burglary, LUX, etc ?
I would propose, to create a generic sensor panel (similarly to the current temperature panel), where you can select which ever sensor you want to analyze.
How can I get the humidity data analyzed and exported?
Are there any plans to implement something like this?
thnks
Josef
7 answers to this question
http://192.168.1.36/api/panels/history?from=505952000&to=1508579311&deviceID=547
http://192.168.1.36/api/panels/event?from=1433076212&to=1433079828&type=time&deviceID=732,546
http://192.168.1.36/api/panels/event?from=1433076212&to=1433079828&type=time&deviceID=9
about temperature
http://192.168.1.36/api/temperature/now-36000/now/summary-graph/devices/temperature/9
192.168.1.36 - your HC
    Thanks for the hints. The easiest for me is to download the data with
      (nnn is the rest of the TCP/IP address of your device)
    This downloads all available device data.
    For the analysis and visualisation, I created an Excel file converting the times, and sorting all the data by device. While this works, this is neither elegant, nor professional....
    So the question remains, when Fibaro will be so glad to provide a professional interface.
    (By the way, the current temperature visualisation solution of fibaro is not really elegant and user friendly either....)
    On 4/27/2018 at 10:25 AM, AndyY said:
    +1
    Hi Joska! Please, can tell me how do you exported the series in excel from the format that is outputed by the api
    The raw data outputed by the apy look something like
    [{"id":12,"deviceID":21,"timestamp":1541824110,"value":"12.29"},{"id":11,"deviceID":21,"timestamp":1541820014,"value":"12.48"}, ...]
    Thanks!
    Edited by LMD
    Dear LMD
    Export the sensor data as formatted. This should look like this
    /monthly_2018_11/image.png.0047dc456436bec9d8d9156fcdcc0a52.png" alt="image.png.0047dc456436bec9d8d9156fcdcc0a52.png" />
    Import in Excel and copy-paste into the "RawData" worksheet of the attached Excel workbook.
    There are two result worksheets:
    1) The worksheet "Processed" just re-formats and lists the data in chronological order as it is usual in Excel. As the data in this worksheet can not be sorted (well it could, if one copy-paste it as text), I made an trial to make individual colums for each device.
    2) The worksheet "Tabulated " does the same as before, but puts the data of each device into it's own device-specific column.
    Of course, you can extend the ranges just by "pulling" the cells.
    The files can get quite large, so perhaps a macro doing the same would
    Have fun
    Josef
    1 hour ago, Joska said:
    Dear LMD
    Have fun
    Josef
    Thanks Josef!
    The problem is that after I access the data from Fibaro api, using  http://192.168.0.100/api/panels/event?from=0&to=10000000000
    I receive a file formated in json format:
    The problem is that I do not know how I can import it in your first sheet, called "RawData": copy-paste will not work because will paste all the data in the first cell, and not in the format that you present in "RawData" sheet .
    in case you are still looking for a solution. i opened the text file in word. did 'find replace' on },{ with a manual line break (see 'special' box at bottom of replace menu). and then removed the [{ and }] strings at beginning and end.
    resaved the file as .txt and then imported to excel as comma delimitted text.
    far from elegant. but it did the trick...
