Please help with while loop :(
I am not a programmer at all, but I would like to create a scene to check room status.  Scene triggers when fibaro door sensor detects open (value = 1). Then check if people is away, if it is, then start to wait for motion sensor breached.  I try to use a while loop for waiting sensor value change but it does nothing, after counting is done the scene stops.  My goal is once motion sensor has breached, then stop loop anymore and process the action written below (pushOver / start scene etc). Please anyone can help me! Below is the scene.
Edited by Sirhideo
hi!
1) remove from the header sensor value
2) write a script with simple check what you need
3) run a script every 5 mins for example
example:
if temperature outside < 10 *C - check is a door opened more than 5 mins. send popup and push notification to all users (hour-long)
for scheduling, you can use schedule script from this forum or simple write another script:
Edited by 10der
    Took me hours to understand your code haha, thank you very much indeed! I will give it a try.
    Edited by Sirhideo
