MdeRijk 0
I run version HC2 4.180. I have a swipe and try to change parameter 10 to clockwise. I save the parameter, see it in window above:
[21:44:57] ID 102: Set parameter 10, value = 31
But if I look at the parameter 10 , the tick mark is gone and at the right it says: last value set
I don't see additional information in the window above. If i press save button again I see
ID 102: Set parameter 10, value = 15
so nothing changed.
My swipe is attached to the power and I have tried multiple browsers, versions, windows, Mac, nothing different. I am logged in as superuser (email adres).
I have tried to delete and add the swipe again, but no change in behaviour.
I can only change parameters from other devices like the motion sensor if I change the parameters from the parent device (hidden).
Anyone the same problem and hopefully a solution?
