Hi!
I don't know if anybody will it be interesting...  but
1) install VS Code
2) download and install LUA plugin
3) let's test
* new file
* save
main.lua (it's important)
4)
6) press F5
6) add config by default
replace launch.json with
7) press F5 again
yay!
your first LUA script in VS code done!
integration with Fibaro
create inside your application dir (folder) "lib"
unpack libs.zip (attached)
1) open launch.json
2) modify:
add
your config now looks like
let's coding
fibaro:debug("Hello fibaro!")
F5
yay!!
so., now you can debug any Fibaro scripts.
"arg0":["-lfibaro_emu"] - prelaod fibaro emulator
"arg0":["-lfibaro"] - prelaod real fibaro bridge
note: change ip address and basic auth for your HC2
lib\fibaro.lua
simple sample :)
happy debugging :)
  • Like 5
  • 1 month later...
  • 1 month later...
On 6/16/2018 at 1:14 AM, antonkristensen said:
Anyone that knows how to get this to work on macOS?
I can only get as far as modifying the config the 1st time.
    about macOS.
    I have old mac os device (mac mini 2012) and ok will do on this a weekend playing with it.
    I'll keep you in the loop!
    2 minutes ago, 10der said:
    about macOS.
    +1
    Edited by SYSMANFIBadb
    commented
    edited
    I'm sorry, the debugger doesn't support linux. I don't have a linux test environment, and debugger.dllsupport linux should be simple but debugger-inject.dll support linux I have no way, especially for the planned new features.
    My current plan is to support x64, support attach to process, support multiple versions of Lua (eg 5.3 and 5.4).
    i have installed
    Super cool !! Thank you very much @10der ! Will install just after my summer holidays :)
    • 3 months later...
    Brilliant! Many thanks
    • 5 weeks later...
    On 7/21/2018 at 12:35 PM, 10der said:
    i have installed
    Could you share with us your steps? :)
    @antonkristensen Mac Os. I can't. Some functions not provided here.
    Edited by 10der
    Ah thats unfortunate, is it because of the LUA debugger tool then ?
    Perhaps we could contact the creator of the tool and check with them...
    • 3 months later...
    Hello!
    Can you please help me where exactly should I put the lib folder I unpacked?
    Thank you!
    Create a folder with name Fibaro
    <enter>
    Create folder
    libs
    unpack into libs folders libs
    back to fibaro folder
    create a new file
    "fibaro.lua"
    past to this file
    package.path = package.path .. ";./libs/?.lua";
    package.cpath = package.cpath .. ";./libs/?.dll";
    require("fibaro_emu")
    save
    create another one
    test.lua
    if require then
        require("fibaro")
    fibaro:debug("I love Fibaro!");
    after I installed VSCode and created the main.lua file and I installed the Lua Debug and replaced the lunch.json it gives me "cannot find debug adapter for type 'Lua'" error
    Any Help ??
    step 2
    can you look on screenshot the1st message?
    Edited by 10der
    • 6 months later...
    Hi @10der,
    Thank for this job ! Have you updated since since this post other function in fibaro_emu.lua ? like fibaro:isSceneEnabled ?
    Have you a way to launch a scene with args in parameters ?
    Thank in advance
