I am planning to install a Z-Wave water valve.
Who has experience with this? I see brands like Popp Flow Stop, ECOnet, Zipato, Xenon, ... but they all look alike? Are those the same?
Tips and trick?
Edited by T.Konopka
https://forum.fibaro.com/topic/30009-how-to-properly-attach-images-and-clips-to-your-posts/
Hi @Sjekke,
i have multiple bad experience with the type of first picture.... It can break and it can only partially close...
    Hi @Bodyart, thx for the info.
    This is of course not want I want, it should work 100% else I need to buy an extra Fibaro water sensor :) I want a solution for my sprinklers, maybe there exist another solution. The search continues ...
    What I use is a simple, standard electrical valve (e.g like this one)
    The one I have is normally closed, 24V to open it. I use a fibaro wall plug with a 24v adapter plugged in to switch the sprinkler on/off. Works perfect for some year already.
    Rene.
    Rene.
    Hi @ReneNL, if I click on the link nothing happens. But is it something like this?
    Hi @Sjekke,
    Indeed, something like that. See for example here:
    Best, Rene.
    hi @ReneNL,
    Thanks for the link. Not expensive.
    Do you use for your sprinklers?
    Groeten,
    Sjekke
    Edited by Sjekke
    I would also like to have a robust 1/2" mains water stopper.
    The only ones I find is US spec .
    Edited by T.Konopka
    Hi @Soft I took a look at the price now ... and 415$ is to expensive for my project...
    Edited by Sjekke
    Hi @Sjekke, I use it with a garden drip irrigation system (i.e. hose with small holes). I measure the soil humidity and switch on the irrigation for a few hours if soil is too dry. Works like a charm.
    Best, Rene.
