Hi
I would like fibaro to develop a non disruptive backup process.that doesn't require a reboot of the system.
If this could be developed then it would enable a backup task to be regularly scheduled at a cadence set by the user.
Finally if auto-backups were enabled, we would need some type of life cycle management for the backups so the backup drive doesn't run out of space. A solution here could be as simple as a check box to retain the last X number of backups
Thanks for considering
_af
