cant get while do loop to work
Hi Friends
I am trying to create a simple scene where, as long as the door is open the alarm rings, and the moment the door is closed the alarm should stop. I am trying to achieve this via while do loop but without success.
I open the door alarm rings, but it does not switches off when door is closed. Below is the code
The logic is as follows .
If Door Ajar == Armed and breached
then
alarm turns on
and keep on running while the door is ajar
the moment door is closed the alarm stops
what is happening is the while loop gets stuck and you cannot even disarm the alarm in that case  ....
%% properties
204 value
204 armed
%% weather
%% events
%% globals
if (
 ( (tonumber(fibaro:getValue(204, "value")) > 0 and tonumber(fibaro:getValue(204, "armed")) > 0) )
or
then
    while ( tonumber(fibaro:getValue(204, "value")) ~= 0 ) do
    fibaro:call(194, "turnOn");
Edited by sam9s
9 answers to this question
@sam9s no need that if statement at top because it is same as while condition ( ~-= 0 is same as > 0 except your device has a negative value.....)
Edited by Sirhideo
    Ok tnaks below is the updated code, but its not turning on the alarm, even though it shows breached ..
    if (
     ( tonumber(fibaro:getValue(204, "armed")) > 0) .... removed the breached condition as you said its already there.
    or
    then
        while ( tonumber(fibaro:getValue(204, "value")) > 0 ) do -- when condition match, loop below
            if ( tonumber(fibaro:getValue(204, "value")) == 0 ) then -- when this condition matched then...
               fibaro:call(194, "turnoff");
               fibaro:abort() -- whole scene abort
             fibaro:call(194, "turnon"); -- when while condition is positive this statment keeps loop
             fibaro:sleep(1000) -- loop every 1 second
    This code is not turning on the alarm. but HC2 shows gives the mnessage of breached and I can then disarm the scene, but alarm is not getting triggered ..... can you assist
    any assistance will be highly appriciated ....
    Try change code  for turnOn  and  turnOff
    No does not work, surprising to test I created another test scene with only while loop to test if the while logic is working, and to my dismay the moment I put while condition, the IF condition in side stops working. If I replace the while do loop with another IF then statement then the inside IF condition works, but obviously only once, which is not what I want hence the need for while loop, but while loop is not working as intended,. not sure where the issue is .. :(  ..please if someone can help ....
    @sam9s
    Let's make this improvement to see if that helps your requirement.
    Edited by Sirhideo
    I don't think the issue  is the code, usually during the alarm all scenes are stopped. Please make sure your scene allowed to run
    /monthly_2018_05/Capture1.PNG.443d903184b91aa74ecfe97f98974b03.PNG" width="326" alt="Capture1.PNG.443d903184b91aa74ecfe97f98974b03.PNG" />
    7 hours ago, Sirhideo said:
    @sam9s
    Hi Sirhideo,
    Thank you so much this code helped, even though it didnt work exactly, but I got the logic and rephrased the code as below and all worked
    local doorID = xxx
    local alarmID = xxx
    local doorCheck = 0
    local counterTime = 0
    if (
    or
    then
        doorCheck = 1;
    else
        fibaro:abort(); -- doesn't match your requirement, abort scene
    while doorCheck == 1 do
        if (( tonumber(fibaro:getValue(204, "value")) == 0 )
         or
        then
         fibaro:call(194, "turnOff"); -- the moment door is closed the alarm stops
         fibaro:debug('Door is closed, scene end')
         fibaro:abort();
         counterTime = counterTime + 1; -- and keep on running while the door is ajar
         fibaro:sleep(1000)
         fibaro:debug('..Waiting for Door Close .. ' ..counterTime)
    That was not the case here, I know what that option does.
     Just out of my curiosity, I think code below could provide same functionality.
    Off course I might be wrong...
