[SOLVED]mem ok, checksum failed
I have the following problem/question:
Recovery geheugenOk
Checksum:Niet beschikbaar
Informatie niet beschikbaar (onbekende fout)
in english:
reco: ok
checksum: not availeble
is there something i can do to get this done? i am not going to ship this thing to fibaro polen, so if this is the end of my hc2. it will be the end :)
@tinman  sorry tinman, just to get you here, you are the man/woman with the most anwsers :)
Edited by akatar
7 answers to this question
9 minutes ago, akatar said:
checksum: not available
click on "verify checksum" and tell me the result (take 2-5min max)
:luv:
    :luv:
    i can delete backups, they are being removed from the list
    takes 20 seconds, at most
    Recovery geheugenOk
    Laatst nieuwe:2018-05-06 22:01:21
    Edited by akatar
    delete is one thing, but checksum will get saved in db, so just click on the verify checksum button
    i did, the result is in the last post
    do a reboot, ctrl+f5 in browser, but probably pen drive can't get checked. This might be result of bad / missing files, or bad pen drive.
    sure, lot of things
    probably you will have not to do it, remote repair is possible (up to some point)
    sure, lot of things
    I know that a reboot solves this for a short time, i will contact fibaro for a remote repair.
    thanks!
    and problem is solved, case closed (thanks to fibaro support)
