I am trying to get a power reading from my energy monitor but am having lots of trouble trying to work out what code i need to use. I need to get a particular piece of info from this response I get.
I don't have any experience in coding don't have much idea, but a nudge in the right direction would be greatly appreciated.
The exact response from the http request is = [{"cid":"PWER","data":[{"1525674668000":746}],"sid":"740893","units":"kWm","age":6}]
my energy monitor is a efergy monitor.
 is where I got the API details from.
"746" is the value I am trying to retrieve.
When I print (response.data) I get [DEBUG] 16:31:24: [{"cid":"PWER","data":[{"1525674668000":746}],"sid":"740893","units":"kWm","age":6}]
When I print json.decode(response.data) I get [DEBUG] 16:17:02: table: 0x9c41348 -- I don't know what this means
I tested the path here:
and can get the watt reading using this code "..data[0]*" in the json path expression field
Scene code i'm using. I just copied and pasted from another forum post by @Lambik to get the http request, I'l make my own code later if i can get this data out.
Edited by Plank
6 answers to this question
    Thanks for your help, it returns the values in a  table?
    [DEBUG] 21:23:07: { [1] = { ["units"] = kWm,["cid"] = PWER,["age"] = 4,["data"] = { [1] = { ["1525692173000"] = 1186,} ,} ,["sid"] = 740893,} ,}
    Edit: now I see that Dump shows the table structure. so I can grab the values of anything in the first table. But can't work out how to get the value from the "data" table because this  ["1525692173000"] is a variable.
    If it wasn't a variable i would assume I could get the data with this.
    Any more hints would be great
    Edited by Plank
    Update
    I think I have figured it out.
    I can print out the single Watt value with this code.
    I have finally managed to get it all working. Thanks for pointing me in the right direction @10der
    Hello, can anyone of you help me in using this script to read data from a device from SUPLA. I have a device from ZAMEL MEW-01
    By sending a command:
    GET / direct / 642 / VUNZmkZTGJD / read HTTP / 1.1
    Host: svr24.supla.org:443
    I receive data in the JSON format:
    { "Connected" True, "support": 65535, "currency", "PLN", "pricePerUnit": 0.3 "TOTALCOST": 75.74, "Phases": [{ "number" 1 "frequency" 50 "voltage": 244.53, "current": 0775, "powerActive": 92.23984, "powerReactive" - 77.4013, "powerApparent": 185.87388, "powerfactor": 0496, "phaseAngle": 141.1, "totalForwardActiveEnergy": 58.17446, "totalReverseActiveEnergy" 0 "totalForwardReactiveEnergy": 0.05954 "totalReverseReactiveEnergy": 30.72214}, { "number" 2 "frequency" 50, "voltage": 242.55, "current": 2282, "powerActive": 444.04796, "powerReactive": 102.90696, "powerApparent": 542.80834, "powerfactor": 0816, "phaseAngle" - 167, "totalForwardActiveEnergy": 99.21702 "totalReverseActiveEnergy": 4.0E-5, "totalForwardReactiveEnergy": 3.96154 "totalReverseReactiveEnergy": 16.33724}, { "number" 3 "frequency" 50, "voltage": 240.18, "current": 10929, "powerActive": 2565.4368 "powerReactive" - 89.58352, "powerApparent": 2573.56152 "powerfactor" : 0998, "phaseAngle": 178.1, "totalForwardActiveEnergy": 95.0771, "totalReverseActiveEnergy": 0, "totalForwardReactiveEnergy ": 1.16234" totalReverseReactiveEnergy ": 52.39652}]}
    The point is for the scene to write into the parameters read from the device and then the virtual device to display them in the label.
    Something like that:
    /monthly_2020_01/image.png.9dca408dba0978032a84f423e78c572b.png" />
    I have rewritten this script in the way below but an error occurs during debugging.
    /monthly_2020_01/image.png.bac82a3586761cbe3e49eca8d3da63fd.png" />
