[SOLVED]run action only once every day
Hi!
I need run some actions once every day.
for example, I put in script header motion ids values and script always running on motions in the room.
but I need run action only once every day in the provided period.
UPD: after some period I understand what I need not once every day as well as twice (thrice / xxx daily) a day between the period
solution here:
parameters
checkAction(
/// <summary>
/// process name. in english. value stoted at Fibaro global params
/// </summary>
name,
/// <summary>
// function for execute
/// </summary>
process,
/// <summary>
/// time period in string representation (is not requred)
/// </summary>
time_period,
/// <summary>
/// periodic time in minutes. if you wana run every N times (is not requred)
/// <.summary>
periodic
once every day between 07:00 and 21:00
once every day without checking the time
run every 2h  between 07:00 and 21:00
so if we have motion at 10:35... and next motion will be for example at 12:40 and more - action occurred!
notice: global values always auto created
Thank U @10der, very usefull  !
