Schopf16 1
Hi
I would like to start a scene with a button (in my example S1 on an FGS-223), which then runs through a state event machine and takes about 60 seconds. While the scene is running, I still want to be able to react to inputs from the button. I want to do this directly in the scene without using an additional global variable. I cannot interrogate the push button cyclically (polling) because the status of the push button cannot be interrogated by the system, as far as I know.
In the code example above I did not set the attribute "local" for the "counter"-variable and assumed that it is available for further instances. I now perform a second keystroke to start a second instance and set the variable "counter" back to 0. But this is not the case. The second instance is aborted with fibaro:abort(), but the "counter" variable of the first instance is not reset to 0. Does anyone know of a possibility or an example to be able to react to short keystrokes during a running scene?
8 answers to this question
