FGS-213 It does not work anymore
This module worked for 10 days then after together with the dimmer modules no longer responded to the commands on the s1 button I reset both the dimmer and this module, the dimmer now work this module does not work nor from s1 ne from web just do not return on after , 5 seconds in off and from s1 nothing
can someone help me to solve?
Have you tried performing a hard reconfiguration?
Guest chaicka
I believe your issue is likely different. Give what A.Smolinski suggested a try first.
Otherwise, here in my thread below, there are valuable information and inputs from long time gurus and Fibaro which may be of value to help you.
