[SOLVED]Presence Scene strange behavior
This is just a simple scene that sends push message by "pressButton" of individual VD.  With below..
local trigger = fibaro:getSourceTrigger()
if (trigger['type'] == 'property') then
    fibaro:debug('Source device = ' .. trigger['deviceID'])
elseif (trigger['type'] == 'global' ) then
    fibaro:debug('Global variable source = ' .. trigger['name'])
elseif (trigger['type'] == 'other') then
    fibaro:debug('Other source')
I can see which global variable triggers the scene.  However, strange thing is that no matter which Global variable triggers the scene (Only 1 var trigger I can see in debug window),  I always see the message from isAHome, for example:
if B is home, it presses a button of its VD so message is sent my mobile, I know B is now home.  But, I for some reason also the push message related to isAHome , the debug message only shows "Global variable source = isBHome"
My Mobile receives:
A is Home -> next push  -> B is Away (debug: "Global variable source = isBHome)
or.. another example
A is away -> next push -> D is away (debug: "Global variable source = isDHome)
is it programming logic issue or it is a bug?
Thanks...
Edited by Sirhideo
As I myself absolutely love the effort of introducing a bit of humour into our forum, I have to ask you to change the title so that it indicates what the scene is about ;)
    fixed by adding if (  trigger['name'])  == "corresponding_globalvar" )  before every if condition.
    if (  trigger['name'])  == "isAHome" ) then
    if (fibaro:getGlobalVAlue('isAHome') == "true" then
    blah blah blah
