Fibaro Relay Switch for my garage door opener?
Senad Aruc
Dears,
I want to connect Fibaro Relay Switch to my garage door openers wall switch relay, so is this ok?
I want to use it like relay/close switch but not with 220V output :)
Thanks,
Hi @Senad Aruc,
Fibaro Switch 2 uses only 220 V AC. So you need to add contactor or dumb releay between Fibaro Switch and your garage door opener.
  • Hi
    Thanks for the replay and do you have any diagram of the wiring of adding a contactor of dump relay?
    Where can I find the contactor or dump relays on the internet?
    thanks,
    BTW the model of the Fibaro I own is this one: Fibaro FGS-212 Z-Wave Relay Switch
