Run scene only once or twice
Anyone can give an idea how to run a scene only one time?
For example:  if bedroom temperature is under 20 celsius send a push notification.
I set this and i receive continuous push notification if temperature is for example 17 celsius, and i want only 1 notification.
An example will be welcome for block scenes and also in LUA where i can set how many push notification/emails receive when scene trigger.
Thank you
Edited by MDC
block scene, for only one notification:
- trigger on variable = 0 and temperature below 20, send push and at the end of the scene set the variable to 0
- create another scene, setting the variable back to 1, if the temperature is above 20
Lua scene:
both temp check in same scene, with decrease of the variable
For number of push messages, with lua as above, with block you can create e.g. 3 scenes, checking for 3,2,1 (and temperature) and 0 if above 20 setting back to 3 the variable
    Lua scene:
    Thank you,
    in block scenes i figured out, but in lua i need an example, i try but not trigger....i convert block in lua and merge but not work :)) sorry, i'm bigginer in lua.
    Lua scene:
    Can you please explain what variable must to do? Or give an example? Thanks.
