kjetilhansen 7
Hello!
I got myself an UBS and just wondered, there are two inputs, and two outputs... Can I use, say a doorbell button for the inputs and and the doorbell for the output? (if the doorbell draws more than 150mAh then use the UBS to control a relay)
Will this work? When I hooked the doorbell button up to the inputs and finally managed to include the sensor it said that there was 2 IR sensors and one remote control thing...
When I finally managed to remove the sensor (had to force remove) I can't include it again
6 answers to this question
