hello, I saw some videos on youtube regarding smart stairs! in which when you start climbing your stairs, the light will go on in an increasing matter, and will turn off also in such way! can that be done in fibaro and how if yes?
" to "
Temat został przeniesiony z "
" do "
@ramisammour , can you post a video of this solution? Remember to put it in the spoiler
    I posted the youtube link please check it
    @samuel, you mentioned that you created something similar? Or is this your solution?
    Can you share the solution with others? I recommend doing that in
    What I meant is, that I designed the electronics with the pcb and programmed the pic controller (IC), as it isn't connected to the home automation from Fibaro. It's a standalone electronics project.
    I see ;)
    Thanks!
