sam9s 0
Hi All,
I am trying to execute a scent via REST API, from outside via ifttt, now I am able to execute the scene via URL inside the LAN correctly, but when doing from the internet, I am not able to pass username, password of the HC2 in order to run the scene
The url for the scene is like this
http://<<DDNS ADDRESS:11111/api/devices/<<scene ID>>/action/turnON
Now the port is correctly forward, and DDNS also working, and I AM ABLE to run the scene on POSTMAN inside LAN and from INTERNET
Now I want the same from IFTTT where I have the URL BUT I cannot find the syntax way to pass credentials in the body section, that would make the scene run. When I am in postman I put the URL, I put the credentials under Authorization BASIC and when I execute ...The scene DOES RUN, FROM INTERNET as well. But I cannot replicate the same behavior from IFTTT, since in IFTTT I only have body section and no Header or Authorization TAB as is in postmen
PLease assist how can I achieve the same via IFTTT. I think I just need to find a way to pass credentials from the body section in IFTTT.
Regards
Sammy
5 answers to this question
