CWestermark 0
I have scenes that do regulate the light depending on input from the light sensor. However, I would like to disable these scenes when I press the Fibaro dimmer to regulate the light "manually". I guess this can be done with a variable that is set in a scene that triggers when a change of state of the dimmer occurs. Sadly, on the block diagram, I only find
Dimmer == On
Dimmer == Off
Dimmer == Scene Activation (Maybe I can use this to trigger scene were I set the variable?)
Dimmer == Custom Value
I look for some block logic that says
Dimmer == "State change"
then
set variable "Disable scene" == True
14 answers to this question
