Z-wave network configuration
Is it possible to reach the z-wave network configuration file, in the control panel, and modify it manually, according to your needs?
Thank you.
10 answers to this question
What exactly are you trying to do?
    I have a plant with more than 100 modules.
    Sometimes I have problems:
    The scenarios act late;
    Sometimes the commands are not executed.
    I have the doubt that, in some cases, the radio signal tries to be repeated for more than 4 modules.
    This is impossible.
    So, I wanted to correct any pre-addressing errors in the mesh network.
    Am I wrong? Do you have any suggestions?
    Should I associate another control unit via the LAN network?
    Thank you.
    How many scenes are you running?
    How's your CPU usage?
    I'm using only 27 scenarios.
    I will have to use many more.
    The control unit is used, only for home automation management, of a large dwelling: Lighting, Loads, Temperature Management, Roller Shutters, etc.
    For this purpose I bought the biggest ECU: HC2.
    Ram is 50%; Storage is 50%; The CPU is less than 50%.
    Thank You.
    Are there any old devices that may be unconfigured?
    Yes, it is
    Try excluding those devices and see if that solves anything.
    OK. I will do it and then I'll let you know.
    Thank You
    Unfortunately it went wrong.
    Forcing the Elimination of modules that are gone, 40% of the modules have disappeared.
    By invoking the backup, unused modules reappear.
    The problems are getting worse now.
    3 motors have been activated for shutters for no reason causing damage with physical shock.
    Modules have been activated and deactivated without a logic inserted in the scenario.
    Could I have a more direct contact with the Fibaro Factory?
    Could I have an intervention directly from them?
    Thank You
    I'm very sorry to hear that.
    Yes, you can contact our Tech Support at
