Hi, is it possible triggered between scenes?
5 answers to this question
@Enic Please, red the rules of the Forum before creating a post.
The title of the post does not specify what the issue is and the post itself is unclear. Please elaborate on the issue and change the title.
    @A.Smolinski
    I can not find a way to delete the post, can you delete it? Thank you.
    You don't have to delete it, you can edit it. But if you really want to, I can do it.
    fibaro:startScenes(sceneID) ?
    Thanks for answering, I can not find a better way to explain it than to give an example:
    --Scene 1
    %% autostart
    %% properties
    %% weather
    %% events
    %% globals
    valueToChange
    local function tempFunc()
        fibaro:debug(initValue)
        setTimeout(tempFunc, 60*1000)
    local initValue = 0
    if ( startSource['type'] == 'autostart')  then
        tempFunc()
    elseif ( startSource['type'] == 'property') then
       local initValue = tonumber(fibaro:getGlobalValue("valueToChange")) -- first example
       local initValue = initValue + tonumber(fibaro:getGlobalValue("valueToChange")) -- second example
    --Scene 2
    -- global variable = valueToChange
    local function changeValue()
        local result = "1" -- this is an a possible example, it could be a function
        fibaro:setGlobal("valueToChange", "1");
    if ( startSource['type'] == 'other')  then
        changeValue()
    The 1st scene is executed automatically, and gives as value 0,
    The second scene is manual, when it is executed it changes the value of the global variable = 1, since it is a trigger in scene number 1, it is executed by modifying the local variable that it already has, so without having to restart scene 1 it is already would return the value = 1.
    The problem is that a trigger generates a new scene and therefore the value of the scene that is already working is not updated. I'm right?
    The best way, is that the 1st scene works with a global variable, and another scene modifies the value of the global variable, this is the only way I have found to simulate a trigger between scenes.
    Example of how it would look:
    --Scene 1
    %% autostart
    %% properties
    %% weather
    %% events
    %% globals
        fibaro:debug(fibaro:getGlobalValue("valueToChange"))
        tempFunc()
    --Scene 2
        changeValue()
    And why do I say all this?
    - It could have scenes that update the value dynamically, so if they use local variables they will not have to be restarted when saving and restarting (LUA). example: variable count
    - Gives the possibility of configuration through a simple web page through http: Request when scenes based on LUA are used.
    And surely many more things.
    Edited by Enic
