Say you want to use a RGBW module to control other dimmer2 devices in your set up.
The following scene and settings will let you do just that.
Useful also if you are trying to upgrade a old bus wired smart home systems with home run controlled circuits
 to zwave system.
Mount RGBW modules in old system switch locations. Use old bus wiring as 12v/24v RGBW supply.
Replace old din mounted dimmer and switch modules at control cabinet  with zwave devices giving you up to 4 switches
per RGBW module.
Solved, thanks @ReneNL
and @Soporte Life2Better for response time hint
Use this scene, set module to output mode, set parameter 10 to 1 sec
488 = RGBW module id
122  to 118 =  controlled  remote dimmers id's
%% properties
488 value
%% events
%% globals
rgb = 488
dimmer1 = 122
dimmer2 = 152
dimmer3 = 156
dimmer4 = 118
function split(source, delimiters)
    local elements = {}
    local pattern = '([^'..delimiters..']+)'
    string.gsub(source, pattern, function(value) elements[#elements + 1] = value; end);
    return elements
colorstatus = split(fibaro:getValue(rgb, "color"),",")
fibaro:call(dimmer1,"setValue", math.floor (100*(colorstatus[1]/255)))
fibaro:call(dimmer2,"setValue", math.floor(100*(colorstatus[2]/255)))
fibaro:call(dimmer3,"setValue", math.floor(100*(colorstatus[3]/255)))
fibaro:call(dimmer4,"setValue", math.floor(100*(colorstatus[4]/225)))
Edited by Jamie mccrostie
6 answers to this question
    Thinking about this....
    Im actually after input to  channel 1 as a dimmer value when RGB is in input/ output mode with all channels set to input.
    dimmedvalue = tonumber(fibaro:getValue(122,”value”)) — where do I insert the channel 1 bit?
                                                  fibaro:call(125,”setValue”, dimmedvalue)
    What Im trying to figure out is how to use a remote RGBW module connected to 4 push button switches and thru lua have them control 4 seperate dimmer2s.
    Hi @Jamie mccrostie,
    The LUA commands to set the individual color channels are:
    With RGBWid your device ID, dimlevel a value between 0 and 255 (i.e. not 100). Instead of "setG" you have "setR", "setB" and "setW" for the other channels/colors.
    To read the value is a bit more tricky (at least I did not find an easier way, maybe I missed something...):
    Get the current status of all 4 channel:
    And now you can access the value of each channel by using colorstatus[1] for red, colorstatus[2] for green, colorstatus[3] for blue and colorstatus[4] for white. As the RGBW color status is a number from 0-255 we need to convert to 0-100 for the dimmer (and round it to get integer values):
    Hope this help.
    Rene.
    Edited by ReneNL
    @ReneNL
    Thanks for your efforts not quite what im after though.
    Im trying to use the 4 imputs  on rgb module via attached push buttons to control
    4 seperate dimmer 2s in the system
    The rgb has no strip attached so Im just using it for remote dimmer control.
    Maybe this has to be done in input mode?
    Apologies if I'm still wrong, but I think the above should work for your purpose. It seems you need to get the dimvalue of the 4 RGBW channels and set the dimmer2 dimvalue accordingly, right?
    So the code would be something like (have not tested):
    Edited by ReneNL
    Cool I’ll dive into it tomorrow morning.
    Thanks again for the help
    I’ll report back if I have  success.
