Greetings,
I just update my 2GIG GoControl panel to a 2GIG GoControl3 (GC3) panel for my security and zwave devices.  I tried to get the 2GIG GoControl and Home Center 2 to work together a while ago and made no progress.  Since then i just power off the Home Center 2 and used the 2GIG GoControl panel.  Now that i have updated to the GC3 panel i was hoping to make progress with the integration of the two.
I would like to be able to share the zwave devices (linear light switch [WS15Z], linear dimmer light switch [WD500Z], Linear Dimmer Module [PD300Z-2], alarm.com Thermostat, alarm.com Temperature Sensor to name a few) and the 2GIG 345MHz devices (CO2 dector [2GIG-Co3-345], door/window contact [2GIG-DW10-345 and 2GIG-DW20R-345], Smoke Detector Audio Detector [firefighter by encore], Panic Button [2GIG-PANIC1-345], Ion Micra-2GIG Wireless Window Sensor, Passive Infrared Motion Detector [2GIG-PIR1-345], Super Switch Takeover Module [2GIG-TAKE-345], alarm.com Image Sensor [2GIG-IMAGE1]) between both panels.  The main 2GIG 345MHz items that i would like to get to work would be the door/window contacts and the Super Switch Takeover Module.
For the zwave, i thought that i could just join the zwave device to either panel and then join the 2 panel together and have a primary and secondary.  I have a Vera 3 and i was able to join that to the GC3 panel but i could not get the HC2 to join to the GC3.  When i try to join the HC2 to the GC3, the HC2 acts like it joins but nothing is registered and on the GC3 side nothing at all happens.  Additionally if i have the zwave devices joined to the HC2 panel when i try to join the two panel together, it removes them all from the HC2 panel.  Lucky i took a backup before i started this and just restored from backup.
For the 2GIG 345MHz devices i am not sure where to start.  I have read a few items about people using certain security boards that allow serial or network based communication or people using a PI / aurdrino board and creating some custom software for the interface.  Most of the items i found go back to 2014.
Any ideas or direction would be greatly appreciated
" to "
Temat został przeniesiony z "
" do "
  • 2 years later...
Did you eventually get your Fibaro system with alarm.com?
