Time delay with single switch for Roller Shutter2
Kircher
Hi forum users,
I searched but did not find a solution to my problem:
I use a single switch to control my Roller Shutter 2 device.
Parameter 14 (Switch type) is set to 2 (Single, momentary switch)
So when I press the switch, nothing happens, only when I release the switch, the Roller acts.
This is an unnecessarily delay.
Expected behaviour: Motor acts immediately if the button is pressed.
Is there a way to shorten the time or change the behaviour ?
thanks in advanced
Just to clear this up a bit. You want to be able to operate your RS by holding the SS button? For example, you hold your single switch button and your blinds go down, you release it and they stop, right?
