Dimmer 2 without switch
I had an electrician here today that helped me install some Fibaro switches, among them a Dimmer 2 that I can´t get to work as intended.
It´s supposed to be hidden and only controlled witout a physical switch.
However it is like it isn´t doing anything at all, I´ve connected it to my HC2 but changing dim value or setting it on or off does nothing, the light stays on.
The black and the red wire connected at the bottom of the converter goes to my dimmable led spot lights. Incoming wires at the bottom and outgoing to an outlet to the left.
Any ideas?
Guest spazpeker
you cant use a dimmer 2 with that module you could replace it with a dimmable led driver and then re calibrate the dimmer 2, or replace them both with a psu and fibaro RGB Module
    Thanks, but what is a psu?
