Hey guys, I'm trying to connect the Home center lite but Fibaro finder is not detecting the device nor is the Fibaro App on my iPhone. the HCL is connected to my modem directly into a LAN port but and the power light as well as the LAN light is on. All other lights are off. Can someone please help me set this up. Thanks in advance.
9 answers to this question
    Hey Jamie, thanks for the reply. I've got Fing on my phone. What should come up for the Fibaro for me to identify it? I've got a couple of 'Generic' and something 'Sagemcom F@st 5355' that i cant recognise
    @Bilal1980
    There is a free simple network app that you can put on your cell phone called “Fing”
    Seems  to work better than fibaro finder.
    It may give you a better idea whats connected on what IP address.
    Usally you would see 3 lights once HC has fully booted  internet, lan and power.
    Edited by Jamie mccrostie
    Id just try the couple of generic ip’s in you browser and see.
    Also note Some times  homecenters can take a while to boot up fully
    On my router it says: "fibaro"
    Hey guys, I'm not the most savvy with this. Are you saying to put the 10.0.0.1 in my chrome browser? When I do it just says
    This site can’t be reached
    10.0.0.1 refused to connect.
    Really appreciate your help!!!
    Edited by Bilal1980
    10.0.0.1 will more than likely be your router
    try the ones above that
    Hi @Bilal1980,
    can you retreive the IP of your phone? If so, then donload some IP scanner and search in the range of the found IP like if your IP on phone is 192.168.0.111 then search the range 192.168.0.1 - 192.168.0.255...
    Most routers just say generic that Ive seen, sometimes Maitec
    I have the same problem, how did you solve yours ?
