Heatit and Heating Panel schedule doesn't work
Hi!
I have problems getting a Heatit thermostat and Heating Panels schedule to work. I did get it working once or twice, but if I changed its temperature or set manual mode for a few minutes, the Heatit doesn't react to the schedule any longer. I tried deleting the zone and schedule and re-creating it several times but it won't send anything to the Heatit thermostat. I use and external temperature sensor.
specs:
Fibaro HC2 4.180
3x Dimmer 2
1x mini Plug
1x Motion Sensor
1x Heatit Thermostat v1.7
1x Sensative Strip
6 answers to this question
    Ah I just needed some patience: it goes back to schedule after some time :D
    Hi, what mode did you set on the heatit?
    I assume you use the strip to be the temperature measuring device ?
    I freally struggle to make a script to use strips for temp, to control the heatit, ants set comfort temp to 23 degrees.
    All i’m able to do is to start heating, not heat, and stay at 23.
    Guest kappe
    heatit thermostat have problem with  Heating Panels
    It will work if u delete heat configurateion and create new.
    But if u change once time manualy,  Heating Panels stop working.
    Its older problem, i wrote 10 times, but nothing.
    work in auto and good, dont touch, dont brake ))
    Edited by kappe
    two + years have passed, Fibaro has HC3 now, but the issue is still remains. It's just stops working on schedule, and sometimes stops polling temperature from sensor.
    I'm started to wonder, why did I buy smart heating controller in a first place....
    Has anyone been able to add HeatIt thermostat to the Fibaro  Heating Panels and put them in a schedule?
    Edited by Helm
    Hi @evgeniy_b, what do you mean "delete heat configuration and create new"? I'm also affected by this problem and can not make heating panel work again. I have tried to remove all zones and deleted heating panels for all zones. Unfortunately it doesn't seems to work.
