Hey
I just bought fibaro dimmer 2 as soon it came i wired it up with a 3W led bulb and through my smartthings hub successfully completed the connection. The problem i am facing is dimmer 2 is not working properly ... the led bulb starts flickering as i turn it on or off. also tried it with a 6W led pannel but same result and i am unable to dim both of the lights. Also i am using it without fibaro bypass, is bypass compulsory to use. What should i do in current scenario?? Do i need any special DIMMABLE  lights or dimmer 2 works with all normal lights ??
Yes, in this case, a bypass should reduce the flickering.
Additionally, install the newest firmware update found here:
See if these steps will help and let us know ;)
