[SOLVED]Dimmer 2 and 2-way lighting
I would like to use the Fibaro Dimmer 2 in both 1-way and 2-way lighting for my house with retractive/momentary switches.
I've looked at the fibaro wiring diagram for the dimmer 2 (
) and the wiring is simplified but I would like to confirm the following:
Can I use 1-way retractive/momentary switches or do they have to be 2-way switches?
Thank you,
Dave
Yes one way push buttons.
if multiple then wires in parallel
    Thanks Jamie.
