Simple heat it to 22 degrees, and stay there scene
Hi all,  I'm asking for help to do this :-)
I have 1 of this
and 1 of this
I want to have 2 scenes:
1 keep the temperature between 8 and 12 degrees when I'm not around
2 Keep the temperature at 23 degrees when I'm here.
This is a cabin, and I will turn on the floor heating  before I arrive, one day before or something like that.
I do not know LUA, and I want to manually do this using one iphone, widget if possible.
I have looked at the heating panel, to complicated.
So one scene when I leave the cabin to lower the temp, and one to rise the temp when I'm going there.
If possible, I would like to combine 3 x this setup into one button :-)
I have 3 different floors, and 3 different temp sensors, one in each room.
The internal temp sensor in the Heat-it is useless, so I need to rely on the strips,
and the only way I can find is to use the heat-it as dumb on off switches.
I'm also installing this tomorrow
to control the boiler.
/kim
Edited by Soft
