SRT 321 programming fails
Slim! domotica
Hi everybody,
I'm trying to create a program with a SRT321.
Quite simple program, when the desired temperature is higher then the actual temperature, then a relay module should switch to "on"
however, when loading the SRT 321 into the HC2 it shows all three values, actual, setpoint and base.
When programming, there is only the actual value available!
I need to make a comparisment between the set value and the actual value and with only one value this is very hard to do.
Does anybody have any experience or suggestions how to handle this problem?
Thanx in advance.
1 answer to this question
Hi
Only you have to link the devices in >Panels/Linked Devices Hetaing Add  than choose sensor from SRT321 and add device  there choose the relay
Like this >
Edited by iTibor
complete
