HomeSystem.sk 69
I am testing the new Gas sensor from Zipato
And after inclusion I get the sensor into the system, it looks normal but breaching the sensor does not give anything in the system. Seems like the sensor can not contact HC2.
It works in other systems (Zipato, homee, popp, vera) but in Fibaro it is without status changes.
This is probably the only Gas leak sensor on the market which is great, so can you please have a look at it?
Association group 1 is set with HC2.
