csillag 0
Hi, I have an installation which mostly uses dimmable IKEA LED bulbs, except at one location, where I need a LED strip.
I already have the dimmer 2 and bypass 2 modules installed at this location.
I purchased a 12V LED strip and a matching LED driver, which works, but it turns out that the Dimmer 2 module can only switch it on and off, since the driver is not dimmable.
Could someone please recommend me a good dimmable LED driver that works with Dimmer 2 (preferably with Bypass?)
I am trying to use three if these strips:
(That means 72W altogether.)
The driver they sold me at the same shop is:
Unfortunately the tech page is in Hungarian, but I think you can figure it out.
It's a constant voltage driver.
Thank you.
Edited by csillag1 answer to this question
