i have a smart home System called homee. I would like to configure the fibaro double switch 2 to change state after 3 seconds.
Example:
 turn on the first switch. After 3 seconds, this should switch back to its original state (off). How is that possible. How do I have to set the parameters, so I get this behavior
Thanks!
    Please help!
    Unfortunately, I don't have any homee devices at hand so I can't investigate this for you. I'll move this topic to the more suitable subforum so that other members might notice it more easily. ;)
    " to "
    Temat został przeniesiony z "
    " do "
    I think i can do this with the fibaro parameters direct?But which parameters do i need?
    /monthly_2018_06/image.png.591b4e7a1c701bb394c370fe7be7ec96.png" alt="image.png.591b4e7a1c701bb394c370fe7be7ec96.png" />
    Please help...
    Example:
    Thanks!
    In parameter change parameter 10 on 4 and parameter 12 on 3
    I will test it tomorrow night. Thanks alot!
