Hello
As notes in various threads, subtle typos in a HomeTable reference can cause scenes to fail.
Equally difficult to troubleshoot is the %% properties section of scenes, as this one uses the actual DeviceID instead of the HomeTable reference.
I stumble regularly across these two whenever I add/remove devices or update device names. The attached python script checks that all references can be resolved to id's and vice-versa.
Example output
User configuration is in line 15-19 of the script. IP address, username/password, the name of the HomeTable global variable need to be adjusted. If "verbose" in line 20 is set to False, only errors will be displayed.
Here is the workflow that I use to check the references and IDs:
1. Run the script with verbose = False; edit scenes to remove any error that occurs
2. Run the script with verbose = True; the triggers in %%properties are displayed; review the scenes and check if the right devices are defined as triggers.
Hope this is useful.
/jayrock
