Hi - Brand new to this. I have an HC2 and Harmony Hub. Both were working well until recently where connection was lost. I factory reset the Harmony and attempted a reload of the Harmony Hub Plugin.
The plugin loads and i am able to get the Harmony Pin. On copying and saving it to the HC2 i get the message "Undefined error" Further attempts also fail.
Has anyone had this problem and is there a solutioin?
Cheers
Andrew
Guest dacianova
9 hours ago, dancar said:
I bought an Harmony Elite remote controller.Yesterday I configured and I still have the issue you reported. Anything shall I do to overcome it? Thanks a lot
Undefined error. Please generate a new Pin Code in the „Advanced” tab and press the „Save” button.
I have the same issue. Can anyone help us please?
Edited by dacianova
Please reboot HC2 and straight away go to Harmony plug in. Do nothing else.
I fillowed your suggestion and it works. I created a new PIN just after a HC2 reboot. It is connected and alla ctivities imported. Thanks.
Guest dacianova
You are a life saver! Thank you.
Hello, since 2/3 days, the Harmony plugin under HC2 no longer works ....
I have tried uninstalling / reinstalling it, all activities come back up normally, but nothing happens when clicking on it or with "changeActivityState".
Do you have the same issue ??
