Hey guys,
I wan't to remote control my garage door. My garage door operator (Novoferm Novomatic 200) can be controlled via a potential free wiring (The "F" connectors on attached schema).
From what I understand the "Relay Switch" could be the solution. (I'll have to connect it to the AC though...)
Do you see a best solution?
Thanks !
i gues it is a pulse contact?
or is it:
close contact, door close
open contact: open door?
as far as i know, you can do this with a double switch version 1 (not version 2)
    Yes, it's a pulse contact. Can you post a link to the "double switch version 1"?
    Ok, seems like the single relay switch can do it too, no need to get a double one.
    You're welcome
