Here is a small tutorial that allow you to use SIRI/ Apple homekit on your iPhone/iPad whit your FIBARO HC2 unit.
In order to access from external network you will need an Apple TV or an iPad set as a Homekit
Until now i was running Homebridge on Raspberry PI, but i hate to have so many devices connected, so running on Docker is great.
I attach tutorial as a PDF.
Also you can download config.json and package.json for FIBARO HC2.
For edit config.json and package.json i use Dreamweaver on mac.
Edited by MDC
  • Like 3
i Mdc@ super nice manual wil start today to deploy thanks :D
works like a charme nice to have
Edited by stefke
" to "
Temat został przeniesiony z "
" do "
  • 1 month later...
Looks great. Anyone got it to work? I can't :-(
From my experience: not all synology systems are equally easy / broadly supported. In my case I turn out to have some obscure chipset that forces me to do manual compiling in many cases :s @SmartHomeEddy, maybe this is also your issue?
Thanks. That might be the case. I have a DS1010+. I have Docker and de container up and running, but I have no clue what to do with this error.
Seems a node.js issue. Do you have the latest version / the version recommended for homebridge?
Yes, the latest version
    Hi guys, my version it’s working well since 3 months.
    Thats why I wanted to give it a try :)
    Btw: recommend
    @SmartHomeEddy, I am afraid that I cannot help you. But maybe other people can share their versions to check whether that could be the issue.
    • 4 months later...
    Very useful manual. Great. Works like a charm!
    Edited by Thomasn
    Could this be run as a service in the "cloud" as well ?
    • 3 months later...
    Thank you very much, I got this work on DS918!
    Edited by fdsjkl
    Has anyone tried to install the "homebridge-config-ui-x" in the docker?
    After running the npm command I get the picture below, but when I add the "config" platform in config.json and restart the container I get " 'config' plugin not installed".
    It seems like every time I restart the container, the plugin is gone. Another thing I noticed is I can't find this plugin in any folder in node_modules, maybe it's installing at the wrong location? @10der
    Any help is appreciated.
    @fdsjkl ¯\_(ツ)_/¯
    Got it working!! thank you
    Edited by fdsjkl
    • 2 years later...
    I have made this working with my HC3.
    You can follow the tutorial but you need to use another npm plugin:
    Anyway, here is the config (with the hc3 plugin):
