soil moisture sensor
Hello.
I have watering done on the solenoid valves and the switch.
Now I am looking for a soil moisture sensor that I could best connect to UBS or possibly RGBW.
I do not need to know exactly what the humidity is. I just want to keep it at a certain level.
I considered the solution presented on the M173 sensor forum, but I can not get it.
I was thinking of buying a sensor, for example from gardeny and converting it, but he gives resistance at the output, so I will not connect it to ubs'a or rgbw.
You can recommend me a soil moisture sensor that is available "on the spot" (fast shipping because winter soon: D)
I've seen a dedicated LB-797, but it costs millions of coins.
Regards
The UBS is a binary sensor, which means it can only detect "on" and "off", or in your case "wet" or "dry". Nothing in between.
The UBS cannot measure resistance, as you indicated yourself.
There are moisture sensors available, perhaps any of these:
Hi Antol, below another trail on measuring soil moisture that might be helpful...
If you handy with a soldering iron and don't mind messing with electronics, have you considered using a Z-Uno (
Ian
