Hello
I have two Fibaro wallplugs installed on an Apple TV. One of the two takes seems too far from the signal (terrace). I was thinking of installing a wifi repeater to solve this problem. Is this a good solution?
Thanks for your help.
sorry for m’y english but i’m french !
@Acker
I don't understand your question very well.
  • So your Wallplug is on the terras?
  • 1 of the Wallplugs doesn't function very good?
  • Fibaro = Z-wave, Wifi repeaters won't help you
    Hello.
    Thanks for your answer. Yes my wallplug is installed in my terrace. I command wallplugs by my iPhone and HomeKit. I don’t have  a central to command. So the ordre to command work with the wifi by my Apple TV.
    this is explain my stratégie to extend my wifi...
    thanks.
    @Sjekke This is about HomeKit version of Wall Plugs not Z-wave
    @Acker Yes, repeater can help with Wifi signal because HomeKit version of Fibaro Wall Plug works with ordinary wifi radio like any other wifi device.
    @mszfcz In the meanwhile I understood this. Nevertheless, if the wifi strength is poor, how about his Apple TV
    If you need to control a Wall Plug manually you don't need a Apple TV and you can do that by using only a iPhone or iPad because they are communicating directly with Wall Plugs trough wifi.
    Apple TV works like a hub for HomeKit but only for executing automated rules and for remote access and it uses Wifi too (or ethernet) so both Wall Plugs and Apple TV needs a good wifi network coverage.
    Edited by mszfcz
    Thanks for this details... I'lm going to buy a repeater for my wifi !!!
    No problem, don't forget that Wall Plugs operates only at 2.4 GHz 802.11n wifi band (not 5Ghz). Good luck.
