Vinisz 15
Hi All,
Hope someone can explain this.
I have a fibaro switch outside which has a direct association (for doubleclick) whith a switch inside.
Now, when I "doubleclick" the switch inside there always is response from the associated module and the light outside goes on, no exceptions, thsi always works...
However, when I want to contol that same outside module via a scene or from the mobile app, then most of the times it doesn't respond.
Now I know that the outside module is on the edge of network range but how can it be possible that direct association does work and via the controller doesn't (always) work ?
Does the controller not route through the same module which is associated ?
8 answers to this question
