NEO Coolcam motion sensor no actual LUX values
I've bought a few NEO coolcam motion sensors but none of them is giving an actual lux values back to the controller. Is this a HC2 issue or do I have to look for answers in the NEO documentation?
6 answers to this question
    Thank you! I found out it has to be a 2 byte value.
    I did set association to Group 2. Hope this is what you mean
    Edited by Jackson
    Try setting parameter 9  to 50. Remember to "wake up" the sensor.
    parameter 9 have 2byte size, not 1byte. Check as well if association group 2 has been set to HC2
    Hi, also i have a neo coolcam motion sensor , works fine apart the LUX. I Don't understand what parameters I Need to set and how.
    Anybody explain me the steps on how configure LUX on this device?
    Hi, I have a Neo Coolcam motion sensor as well. Can someone explaine me the steps how to configure this device?
    @T.Konopka @M.Baranowski @JohnnyC how offen Fibaro add templates to centre?
    @Vladyslav , we add new templates when we can.
    A template is only a graphical representation of a device in UI. If a device is fully supported then you can configure it in advanced settings and you can do that without a template.
