Urgently needed: global functions in lua
3JL
1 minute ago, jgab said:
Sidelining rights... well, we keep firearms away from children so they shouldn't hurt themselves - or others ;)
best here!
2 minutes ago, jgab said:
But that's just like a 'require'
if something is "green" and sometimes say "croak-croak"... Look, I mean, it doesn't even have to be a frog... :)
Jan, Fibaro guys prevent accessing to fs. maybe it's right. also IMHO he prevents accessing to some core low-level LUA functions.
require('\opt\fibaro\scripts\remote-support.lua')
but you are right
ok let is be  'require('sceneID')
12 minutes ago, jgab said:
All the fibaro mgmt of scenes (starting, stopping, triggers etc) need to make exceptions for "library scenes" -
yes.
7 minutes ago, 10der said:
best here!
but you are right
yes.
Nice picture. But why would a library need all the confusing (non-functioning) scene options in the GUI? Why not a separate tab for libraries? I guess one would like to reference libraries by names and not IDs as they are not stable (you never now what ID you get when you add/remove/add scenes)
Anyway, I'm not sure we help the poor developer at Fibaro thinking about global functions by just discussing the syntax. There are still all the other considerations I listed in the first post.
...when to load, performance, security, versioning, bloat, support...
I would love to have 'loadstring()' and would check "I voluntary void my HC2 warranty [X]", but I'm not sure others wanting to use my libraries would also do it... or trust me.
cuz what I can propose Fibaro (IMHO) can implement for one sprint.
but if we asking Fibaro "separated tab with Blackjack and Hookers ..." we're going to grow old before Fibaro implement this feature.
Yes, but I think the last thing we need to do is to encourage Fibaro to make the HC2 less trusted :-)
So, my point is that a "petition" for global functions ("straight forward implemented") is like a petition for opening up the HC2... and then people should be aware of that.
A compromise, seen in other Lua sandboxes (games etc) is to have a few approved libraries available for require()... and I guess they could be "precompiled"...
sorry. it's not clear for me?
we can't be asking fibaro allow to use require but we asking to able to use own scenes / scripts.
Jan, please, do not  puts its own spin on the facts.
I'm not spinning anything. Please read up on how 'require' is implemented. Scenes are sandboxed by Fibaro - 'require' execute its code in the global environment - access to os.execute and whatever other stuff that Fibaro doesn't want us to thinker with.
Anyone can imagine pigs flying but it's damn hard to make them do it in reality...
ORLY?
\opt\fibaro\FibaroSceneEnv.lua
There's nothing that prohibits Fibaro devs likewise disable context all prohibits functions in the include file.
and if Fibaro will implement implicitly require  via the header as I said before: is the lesser evil.
9 minutes ago, jgab said:
pigs flying
I have opened a bottle of beer and turn on Pink Floyd
Happy Friday. Sir!
So how would you implement it via the header? Most likely with something like ‘require’ which is inherently unsafe. You can set the environment afterwards but that is too late as ‘require’, ‘loadstring’ etc always use the global environment while compiling and loading no matter what you have set _G to. Any code can execute while it’s loading. No other Lua sandboxed environment out there, games platforms etc,  allows ‘require’ (except for in some cases approved libs).
Please read up on how Lua implements it and we can have a more constructive discussion, and try to come up with a real solution.
When I saw people starting “petitions”without understanding the underlying issues (and no one from Fibaro explaining the issues), I just wanted to explain that it’s not that straight forward...
Jan! I am really want to say thank you for your libs, sharing knowledge etc...
but.... That's where you're wrong. Fibaro uses native C++ libs Luabind
 for implementing scenas and VD's. Devs can include any files on low-level without publishing some methods.
yes it's my IMHO. Sorry, but I'm out.
Ok! you win.
...anyway, I didn't say that 'require' was used to load scenes/VDs. Luabind is to start the scene environment - and you see that they themselves use 'require' to pull in mqtt and netHTTClient - and there is a good reason for that. Note that even though _G is filtered afterwards, mqtt and net* doesn't crash when they are later used because 'require' always have the full environment effectively making the loaded libs running outside the sandbox. Loading multiple lua files with luabind and luaL_loadfile into the same Lua state without conflicts is messy and is why 'require' and its semantic is used. Yes, anyone that has hacked their HC2 can add any file but that was not what the discussion was about. The point was to find a safe, resource efficient, and easy approach. Hack together an acceptable luabind example loading multiple files that share environment and propose it to Fibaro....
Just realising that we run 5.2 now (I was still in 5.1 land) I'm leaning towards a rewritten 'require' using Lua's load(ld [, source [, mode [, env]]]) that seems to be able to load with a sandbox environment. Still worried about precompiling and versioning and efficiency though... Still see sandboxed platforms out there (game platforms etc) only allowing loading pre-provided lua libraries. I guess most common useful lua libraries out there will not work in a sandbox anyway... but this was for users' own code so that may not matter.
  • 5 weeks later...
Just checked the FS content
/opt/fibaro/FibaroSceneAPI.lua - is the common interface file. Its passed to every lua scene process as a parameter (as much as FibaroSceneEnv.lua). I guess its the best place to store common functions for all scenes.
IMHO Would be cool to make some "github" with commonly used functions to keep some "standart" here
HC2 - just to append the file in rootfs
HCL - need to link the file to user_data partition in order to make it writeble (r/o rootfs)
  • 1 month later...
  • 1 year later...
