Sjd101 0
Very new to all this. Only just started with HC 2. Have two devices but will obviously be adding more but wanted to do it one at a time to aid my learning. So the first device I have added is a Conexis L1 Smart Lock. It paired fine with HC2 and I can lock and unlock the using HC2. I have read up on the Master and Slave concept but struggling to configure the master. Slave seemed to configure on adding the device. I have attached a couple of screenshots. How do I configure the Master? The lock seems to work OK without doing anymore.
But what I am really trying to achieve is the door to unlock as I approach it by creating a scene. Just really unsure where to start? I have read up on scenes and tried to create a simple Magic Scene that secures the Lock if it remains unlocked for more than 10 mins but options are limited using this method. However, not sure which variables I would use to out the scene together? I realise I would need to use the block system but a bit out of my depth.
Sure this will all become easier the more time I spend with HC2 but at the moment its all a but daunting so some guidance would be welcome
Thanks in advance
