Hi all.
I am sorry if this will be a lame question and for my english))
I am going to buy some fgs-213 and would like to know: Can i use for s1 switch regular on/off switch (bistable) and for s2 push button (monostable)?
Hope you understand me - thank you in advance.
Edited by hats
7 answers to this question
As far as I know you cannot have different types per switch.
You can set toggle or momentary type, but it is for both switches.
This is correct, pin3 and pin 4 are shorted.
By the way, Switch 2 in FGS-213 is not active.
Edited by cag014
    Thank you for the answer. That will make some problems - but i think i can handle with that.
    Another stupid question - there is short circuit between pin 3 (L) and pin 4 (L) - am i wrong?
    What do you mean? According to manual double wall switch i can connect to the FGS-213.
    fgs213 is not a double wall switch, it's a single wall switch
    fgs223 is a double wall switch
    /monthly_2018_07/Capture.PNG.140feff0aed7fcfaae83e3b26278602e.PNG" alt="Capture.PNG.140feff0aed7fcfaae83e3b26278602e.PNG" />Which manual?  According to fibaro  this is a single switch
    Edited by cag014
    For what purpose there is a example with double switch installation for FGS-213? :
    /monthly_2018_07/Untitled.png.8aad074df2950114935e4a9a1238a101.png" />
    Edited by hats
