janbe 1
I added a Dimmer 2 (v3.5) to my HC2 system. The switch appears in my system with ID:111 and operates properly when operated manually. I can control it via HC2 by using the On/Off toggle switch or slider.
However, it does not respond to the following call:
I've installed the latest firmware on both HC2 and the Dimmer switches. I have tried removing and adding it again to HC2.
Edited by janbe8 answers to this question
