Hello Guys,
I'm looking for a scene or something which can start the sprinkler panel automatically and makes 1 sprinkling loop for a given time then its stops.
I have sprinkler panel set up I'm using relay switches to control the pump and the valves. Its working great on the given times. I want that if I arrive home and see that the grass need water I can hit a button and it makes 1 loop for all the zones then stops. Do you have any idea?
5 answers to this question
I use this great script with a couple of zones. I have also made a VD to adjust the parameters.
Sorry for the Swedish language :-)
Edited by RH_Dreambox
    I'm not sure this is what I need.
    How can I turn on a full srinkler  cycle with this?
    This script does not use Fibaro irrigation panel at all.
    This script works like the Fibaro irrigation panel should work, that is, to water intelligently using air temperature, humidity and rain sensor.
    You can water several different zones after each other
    Longer irrigation times when temperature rises
    The irrigation time is also affected by humidity
    No irrigation if it rains (if you have a rain sensor)
    How do you mean that? You can water several different zones after each other
    I can do it on the phone sprinkler panel also. For this no need virtual device.
    I'm looking for a sceene or vd and when I hit a button its start a full cycle sprinkling for example 5 minutes. starting zone 1 for 5 minutes then zone 2 for 5 minutes then zone3 for 5 minutes etc. And only need to push a button on the beginning.
    hello
    can you share that VD you made??
    are you still using the scene for watering?
    i am trying to find a way to control my watering .. i have 10 zones and want to control them with my HC.
    hardware is set up buy i have nothing for decent control over them
    Christos
